In the last couple years or so Sim Mechanical has gotten really good at matching meshes of surfaces that I import from CAD even when I don't make sure all the line and arcs where they join are on the edge of a surface. In other words I can take a plate then just stick another plate at right angles to it in the middle of the first plate and Sim Mech is smart enough to know the surfaces meet there and mesh accordingly. I made a CAD model of some plates attaching to a pipe normal to the pipe and it meshed wonderfully. I then pulled the plates apart a bit being careful to move them along the length of the pipe only and not move their curved edge off of the pipe. This time the meshes didn't match. I assumed I must have a gap between the plate and the pipe but I can't see one. And yes, "Create matched mesh between parts" is checked. I've done this tens, if not over a hundred times, and it works wonderfully. This time it failed and I can't see why.
Short of going back to my CAD model and starting all over, is there anything I can do to make those suckers match? Oh, and short of moving each node manually.
