I am running a static stress analysis with linear material models.
When I got to enter my custom material properties, I am either prompted with this:
or the material properties show up, but when i click apply, I am prompted with:
The material you have selected is incomplete. Please review the items which are flagged with a "red light"
I am running Autodesk Simulation through Parallels on a Mac, but I don't believe this to be the source of the issue.
I already tried the solution given here:
Was hoping someone could give me some advice/point me in the right direction, haven't been able to find anything else on the forums like this.
thank you!
Hi Trbrodt,
Which version of Simulation Mechanical are you using? You can determine this by going to the "?" in the upper right and selecting "About". You will see a build number in the format 2015.XX.XX.XXXX MM-DD-YYYY.
Are you using a different number format system from the US/Imperial standard of , for group seperator and . for decimal seperator? This is typical in Europe and other countries with the . as the group seperator and the , is the decimal seperator.
The message implies that the unit system is not defined. Obviously, you would not have gotten to the point of being able to enter material properties if the unit system had not been defined, so this indicates a problem with the software being able to read the model.
I think there is a 95% probability that the problem (or a problem you have not yet encountered) is because you are running on a Mac. There are too many obscure things being used by Sim Mechanical that I think it is unlikely that all of them will work on the different architecture. The other possibility is the name of the model or any of the folders in which the model is stored. If the name includes any non standard characters (anything other than a through z, numbers, and a few "special" characters like - and _), that could be causing a problem.
I have also had this same problem with the material properties of my custom libraries.
Editing or adding the material from FemPro shows no properties or it wants to convert. I had been working back and forth between SI and metric in tree.
Library manager shows all properties, but not in FemPro.
If I create new library and move material to it, it showed correctly.
I am running Win 7, 64 bit, Sim 2015 SP1 latest version.
Not much help, but you are not the only one with this problem.
