Graphs from Thermal Simulation
Is it possible to extract the numeric data from the results of a thermal simulation to plot graphs in order to analyse the results more effectively?
John_Holtz
Autodesk Support
Autodesk Support
Yes.
What would you like to do that is not covered by one of these Help topics?
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
I want to select specific nodes on the simulation and create a graph of temperature against time. Having read those pages you have supplied, they do not match up with my layout of fusion. It instructs me to use the results command however I do not have access to the same options that they do. I have attached a photo to try and help you better understand my predicament. Thanks for the help again.
John_Holtz
Autodesk Support
Autodesk Support
Since you are using Fusion, you should post your message to the Fusion forum instead of the Simulation Mechanical forum. Simulation Mechanical is a different program.
But Fusion only performs steady state heat transfer analysis, correct? If you want temperature versus time, you need to perform a transient analysis. Inventor Nastran and Simulation Mechanical  will perform a transient heat transfer analysis.
John Holtz, P.E.
Autodesk, Inc.
