Combining Surfaces
Combining Surfaces
Combining Surfaces
I am running an electrostatic field strength and voltage simulation for a MEMS device, but am having a problem specifying the "Invoke Force/Charge calculation" surfaces.  I have a lot of surfaces that I need information for, and was wondering if I could specify only one surface.
I saw in a tutorial, located here, in which multiple surfaces are combine into one surface.
I have been looking for a long time on google and these threads, but have not found any way to do this.
Thanks a lot for your help,
Mike
John_Holtz
Autodesk Support
Autodesk Support
Hi Mike,
Select the lines that you want to change. The easiest method is to first select all of the surfaces ("Selection > Select > Surface" while holding down the Shift key), then select the lines on those surfaces ("Selection > Subentities > Lines").
Change the surface number of the selected lines. ("Draw > Modify > Attributes")
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
Thanks a lot,
You have saved me a lot of time!
