Screencast Recording Utility has stopped working
As the title of this thread says: "Screencast Recording Utility has stopped working".
Uninstalling and reinstalling does not solve problem.
Any ideas?
ram.mummidi
Hi @Anonymous,
Was it working before and suddenly stopped working or is it the first time you installed and it never worked for you. Looking at the screenshot, I am assuming you are windows. Is it possible for you to got to %temp% folder in windows explorer and look for Screencast.dmp file and email that to the following email address: screencast.feedback@autodesk.com
--Ram
Ram Mummidi
Principal Engineer
i already send you the email, what shloud i do now?
ram.mummidi
Hi @Anonymous
Thank you for the Screencast.dmp file. I will take a look at this tomorrow. In the mean time, can you please try the below steps and let me know, if this fixes the issue for you:
- Reboot the machine so that all the resources are freed
- Uninstall the Screencast Recorder
- If for some reason, if the uninstall doesn't delete the following directories, go ahead and delete the following directories:
    C:\Program Files (x86)\Autodesk\Chronicle
    C:\ProgramData\Autodesk\ApplicationPlugins\Autodesk Chronicle.bundle
    C:\Program Files\Autodesk\Chronicle
- In registry (Run regedit), and delete *Screencast* Key from the HKCU\Software\Autodesk
--Ram
Ram Mummidi
Principal Engineer
emodderman
My screencast has stopped working as well. i have cleaned all my screencast folders and uninstalled more than once. there is nothing screencast on my computer.
When i reinstall, the program loads and then closes right away. no crash error, nothing. i need this software and i cannot get it working!!
Help!
gperego
I had the same problem, but I solved following this solution:
https://forums.autodesk.com/t5/screencast-forum/will-not-launch/m-p/9027038/highlight/true#M2284
Regards
