Record Audio From Computer?
Message 1 of 12
Can you record audio that is playing from the computer with a Screencast? Not the audio from a microphone. But, the computer audio.
Replies (11)
Message 2 of 12
nguyenph88
Hi @Anonymous,
Thank you for your feedback. we do not support that feature right now but it's a good idea to have that in the future. I think there is a workaround but I haven't tried myself, instead of using a recording device for input sound, you can try to select any internal output device to be your input sound devices.
Thank you,
Peter Nguyen
Message 3 of 12
Some time ago I suggested to add / to merge system audio (computer audio) to user audio. Just to replace the micro with computer-audio is only the half solution - an option "use micro only / use computer audio only / use both micor and computer" would be great.
Message 4 of 12
Record audio from the computer is required a recorder tool. As for me, I used to record the audio from the computer via TuneFab Screen Recorder to help me with recording all the audio that I want to keep. Hava a try!
Message 5 of 12
FonePaw Screen Recorder can record both system&mic sound and it is also easy-to-use. You might want a try. OBS is also an excellent open source screen recorder which can record system&mic sound. You can use any of them up to your will.
Message 6 of 12
I guess what you have said is to record the system sound from the computer. I think it is particularly easy to achieve using VideSolo Screen Recorder.
Despite being named after screen recorder, it actually includes the feature of the audio recorder. It is capable of recording both system audio and microphone audio in lossless quality.
It has two versions respectively for Mac and Windows. You can try its free version to see whether it suits you.
In case you are in urgent need, check here to see how to record audio with it.
Message 7 of 12
If you'd like to capture the audio files playing in your computer, here a think you can take a try with Aduio Capture for Windows, which is a smart audio recorder allows you to capture any music track as MP3, WAV, AAC, FLAC or other common formats so that you can play them on any device freely.
Message 8 of 12
As for me, I usually use Joyoshare Screen Recorder Windows to capture audio from computer. The most satisfied part of this tool is that you can freely to record only computer system audio or microphone sound or both, as you like. The quality of audio recordings is great as well. You can give it a try.
Message 9 of 12
To record music from computer, you can try this tips to use an Audio recorder.
Unlike other software, this tool use the advanced technology, it is fast and quick.
Hope this tips helps you well.
Message 10 of 12
In order to record music from computer, you can refer this tips to use an Audio Capture. Being Different from other tools, this one use the latest technology, which runs fast and stable. Hope this tip can help you.
Message 11 of 12
Yes, I use Joyoshare Screen Recorder. It can only record audio from the system.
Message 12 of 12
The easy solution to record audio from computer is use a third-party software.
I know windows player can record system sound too, but the sound quality is just not very good.
So the tool I'm using is joyoshare audio recorder, and it can also edit the recordings conveniently.
