I make 3D model for the petrochemical industry with Plant3D and then I use Navisworks as a viewer.
Then, I develop plugins with Navisworks to add some functionnalities.
But, it is not possible yet to develop an Android viewer with lots of functionnalities.(would be nice to do simulators)
I tried to make an app with Unity, however, my P3D models are far too heavy. Because to import them on unity, i need to convert NWD into FBX.
Is it possible to import some autodesk model with a "light" format into Unity?is it possible with SCALEFORM?
Damien
Solved by thamerm. Go to Solution.
Hi Damien,
Thanks for your question. Scaleform will allow you to play Flash content (such as UI or 2D graphics) in Unity, but it would not help with the problem of creating lighter 3D models from NWD or FBX.
Thank you
Hi Thamerm ,
Thank you for your quick answer.
I have the feeling there is no easy way to import a huge autodesk file into unity.
Damien
