The Scaleform forum is now read-only. Please head to the Gamedev site for product support.
Directory "/Integrations" missing in SF4.4 Mobile iOS deploying for Android
Hello everyone,
Have in hand an almost completed project. With sf4.2 my app worked perfectly in both iOS and Android 4. But as you know, the need to compile for ARM64 on iOS, and Android 5 incompatibility with sf4.2, forces me to make the jump to sf4.4 .
With sf4.4 I solved most of the problems that I found on iOs, and I managed to have a fully functional app. But when I try to create the android version from windows, I find problems with loading external files and music, and I can make my app to work.
I thought maybe the Android version of MacOS everything would be fine. But when I try to make a Deploy for Android from MacOS with "Scaleform mobile 4.4 for iOs" I get a compile error.
Our settings: Yosemite + apache-ant-1.9.4, android-sdk-macosx, android-ndk-R9D: This the short log I get:
Created deployment definition /Users/grupo/scaleform_4.4_iphone/LocalApps/testandroid.def
Preparing to run build tools ..
Copied player source file into project directory at /Users/grupo/scaleform_4.4_iphone/LocalApps/testandroid/FxPlayerMobile.cpp
Created player options header at /Users/grupo/scaleform_4.4_iphone/LocalApps/testandroid/FxPlayerMobileOptions_Android.h
Can not find SparkPlayer files at /Users/grupo/scaleform_4.4_iphone/Integrations/Android/SparkPlayerShippingBase basis, please restore before continuing..
I searched "Scaleform 4.4 mobile for iOs" but there is no "Integrations" directory. I copied the directory "Integrations" from "Scaleform 4.4 mobile for Android", but the error is the same, since no dir found named "SparkPlayerShippingBase"...
Please, can anyone guide me to get compile from iOs Android? Where can I found the right "Integrations" directory?
It's a mistake the reference to "SparkPlayerShippingBase"?
Thanks!!!
adjm
Hi Mike,
Sorry for the trouble you are having.  It sounds like you are trying to Deploy to Android using the iOS SDK package.  Unfortunately this won't work without a messy process of merging the two SDK packages.  It's best to keep the two SDKs in separate directories to ensure everything works as expected.  Please see my recent thread regarding some fixes I have made to the Android Deployer based on customer feedback:
http://forums.autodesk.com/t5/scaleform-mobile-development/scaleform-4-4-mobile-sdk-android-deployer...
Once these are verified and everybody is happy, I will move onto some minor issues with the iOS package, after which we will issue fully updated packages for download at the usual place.
Jeremy
Scaleform Engineering
