The Scaleform forum is now read-only. Please head to the Gamedev site for product support.
Black screen on Android & Android make error
I have tried to follow this tutorial but I haven't been able to do either of the two things shown in it:
1. Getting the FXPlayerMobile app to load an SWF (I tried with 3DGenerator_AS3.swf and ScaleformLogo.swf both of which I named (not at the same time of course) "flash.swf" and put in the root of the internal memory of my phone).
      - When I run FXPlayerMobile on my phone I only get a black screen. Interestingly the menu of the app works (but only takes up half of the screen, I don't know if that's the normal behaviour)
     - I use a Galaxy S3 I9300
2. Making an apk out of the StarforceTD.swf. I followed the tutorial closely but when I run "make P=Android C=Release+NoRTTI" I get this error:
      - I have installed all the cygwin packages that were said to be necessary (binutils, g++, perl, make). I have also checked the checkbox that asks me to install the packages that these 4 need to function properly.
Seems like you don't have your compiler configured properly. The command line shows that the compiler used by the cc command is Android-g++ which I guess it should be g++.
Take a look at your .bashrc or bash_profile (in your cygwin HOME path) see if you have something like this CXX=-g++ or just try to compile something with cc. If you can, maybe it's Makefile's fault (it's using a hyphen instead a blank space) take a look at it.
If after that, you can't solve the problem you can always type
$make P=Android C=Release+NoRTTI P_CXX=g++ P_CC=gcc
it should compile.
Hi Dani,
I think you are right about it being makefile's fault. Look at this:
I can type in anything as a platform and it will appear in the error where "Android" used to:
Then I went into the makefile and this line looked suspicious to me:
I inserted a random string in there to see if it would appear in the error and it did:
I don't think that "$(PP)" (which is the platform name plus a dash) is there by mistake because it's there for all compilers as you can see in on of the pictures. Can you check your makefile and see if it's different there?
I didn't try any of your other suggestions yet, but I will.
I have also tried entering "make P=Android C=Release+NoRTTI P_CXX=g++ P_CC=gcc" as you suggested and the message was a lot longer (as you can see here), but the last error was similar: "Android-ar: Command not found".
I have also checked the two files that you told me to check and neither of them contained the string "CXX" at all.
adjm
Hi Guys,
The Scaleform 4.4 Mobile SDK was released which adds a lot of great fixes, moves everybody to the latest Scaleform 4.4 codebase, and adds 64-bit Support for iOS:
http://forums.autodesk.com/t5/scaleform-mobile-development/scaleform-4-4-mobile-sdk-has-been-release...
Please try updating to this version if you haven't already and let us know if you continue to have issues.
Jeremy
Scaleform Support
