I would like to point a error of Robot 2016 (also in Robot2015) that in the Column Design Model, the height of the column is incorrect.
The height presented there is h+1/2 height of the beam or slab on top of the element.
It's better explained on this post:
http://forums.autodesk.com/t5/robot-structural-analysis/wrong-height-of-components-after-importing-i...
Is there a way to hot fix this, caus it gives more steel then necessary and when export to Revit, the rebar will end later or before the real ending of the column, dependind the condition of what's on robot.
Vítor Pascoal
