Composite structures by EN 1994, merge bars function,
1. Full support of calculation steel-concrete (composite) structures with fire resistance by EN 1994. Composite beams with connection of RC plate to upper flange, slim-floor beams, partially-encased columns, composite columns from tube sections with or without H-section in it and etc
2. There is "Divide" function in Robot, but often need reverse function - "Merge bar" function to merge small bars into one.
1 Comment
dimogrec
These ideas are already proposed 2-3 years ago (with no much success specialy for the first one). So please support them
http://forums.autodesk.com/t5/robot-structural-analysis/composite-members-steel-and-concrete-ec4/idi...
http://forums.autodesk.com/t5/robot-structural-analysis/merging-two-bars-into-one-bar/idi-p/3701596
For the moment merge bars could be done using this application (api) ->  http://forums.autodesk.com/t5/robot-structural-analysis/api-addin-for-merging-bars/td-p/3817730
