Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
wrong units displayed in member type definition
6 REPLIES 6
adelmoparigi
388 Views, 6 Replies
attached member type definition  pls note that
units for b1 and b2 are shown in m  ( meter?) even if i work in imperial unit
6 REPLIES 6
hi @adelmoparigi
try change Job Préférences:
Best Refards
adelmoparigi
in reply to: adelmoparigi
hi thanks for quick reply
but in job preference i already set all units to imperial for example  (see in my the attached  screenshot )units for "support width beginning are alrady set to imperial unit " are set to ft  seems a mixture between imperial and metric
HI @adelmoparigi
Unit is incorrectly displayed in this dialog box. (not updated when changed in preferences).
In those fields Structure Dimensions unit is used. Defined value is recalculated after unit modification in Job Preferences.
I will report it to Developers.
Krzysztof Wasik
sorry but i am not sure to understand
this is due to my mistake i mean wrong setting ?
Hi @adelmoparigi
No, it is issue in the software.
Krzysztof Wasik
okapawal
This issue has been corrected in Robot Structural Analysis 2024 release. Release notes
Corrected unit for slab width on the dialog for beam parameters in required reinforcement module.
Waldemar Okapa
Sr Product Owner
Technology Administrators
