attached member type definition pls note that
units for b1 and b2 are shown in m ( meter?) even if i work in imperial unit
hi thanks for quick reply
but in job preference i already set all units to imperial for example (see in my the attached screenshot )units for "support width beginning are alrady set to imperial unit " are set to ft seems a mixture between imperial and metric
Unit is incorrectly displayed in this dialog box. (not updated when changed in preferences).
In those fields Structure Dimensions unit is used. Defined value is recalculated after unit modification in Job Preferences.
I will report it to Developers.
sorry but i am not sure to understand
this is due to my mistake i mean wrong setting ?
This issue has been corrected in Robot Structural Analysis 2024 release. Release notes
Corrected unit for slab width on the dialog for beam parameters in required reinforcement module.
