Wrong height of components after importing in design module
Μηχανικος
Μηχανικος
Hi, i have just noticed that when i import a column into the RC provided reinforcment module the height of the column is wrong and i have to change the height from RC element -> Column Geometry.
all of my storey heights are 3 meters, but when i import a column from 2nd storey the height id 2.95m
also when i import a column from the ground floor the height is 3.25.
However when i am in the Structure model module and click on one of the columns the height is ok at 3.0m at all storeys
any ideas?
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please check:
http://forums.autodesk.com/autodesk/attachments/autodesk/351/24399/1/RC%20column%20heights.png
Artur Kosakowski
I also posted the same problem in robot 2015.
I'm not entirely sure that in robot 2014 we didn't had this problem.
Isn't possible to fix this?? this is something that is wrong, cause later, if i want to transfer the rebar to revit, the bar from that column (and obviously all of the columns that have + or - 1/2 height of beam/floor) is ending before or after the correct ending of the column.....
I know we can change manually, but we have to do 1 by 1, and if a building has 100 columns.....
Like i said, is there a way to fix this???
Vitor Pascoal
Artur.Kosakowski
Autodesk Support
Autodesk Support
Please post this request here:
http://forums.autodesk.com/t5/Robot-Structural-Analysis/idb-p/93
Artur Kosakowski
