Does Robot provide both P-Δ and P-δ analysis?
raried
raried
See attached image that shows difference between P-DELTA and P-delta.
The AISC 360-10 code requires both are accounted for in the design unless the P-δ can be shown to be negligible (which I am studying on my current project now). Curious to know if Robot can do this anyway. I have looked through the analysis type parameters, the forum and google searches and have not found an answer. Any help appreciated, Regards, Rob
Rafal.Gaweda
Autodesk Support
Autodesk Support
raried
Hi Rafal,
Thanks for your quick response.
I have read through those links (actually read before posting). You're right. The beam with fixed supports does indicate that P-δ is included.
So I cannot choose between 1 and 2 below as Robot does 1 as standard. Is that correct?
1. P-Δ and P-δ
or
2. P-Δ
Many thanks, Rob
Rafal.Gaweda
Autodesk Support
Autodesk Support
raried
Further question. From the diagram shown on this page:
http://knowledge.autodesk.com/support/robot-structural-analysis-products/learn-explore/caas/CloudHel...
And the comment on this page:
http://forums.autodesk.com/t5/robot-structural-analysis/non-linear-analysis-p-delta-analysis/m-p/364...
regarding needing more nodes along beam for increased accuracy.
If I have a space frame with nodes only at framed locations (i.e. no nodes along the length of the individual members) would this effectively be P-Δ only?
Rob
raried
Thank you Rafal, that link answers my question.
Rob
Rafal.Gaweda
Autodesk Support
Autodesk Support
Yes.
Rafal Gaweda
