How to define Clear cover of Slab?
I have run drawing of a slab details but it is showing slab clear cover is less than required clear cover as per design code. How can edit clear cover to fulfil the code requirement??See attached figure.Thanks in advance.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Change cover, run required slab reinforcement design again, import slab to provided reinforcement modeule
Rafal Gaweda
Thanks for the solution, but When I am trying I am facing problems. One is bar dimension is not changing, other one is clear cover is not changing. See my attached files.
