Incoherent Mesh on edges and distorted elements
Message 1 of 9
I have various incoherent meshing edges in the attached model, is there a better way to avoid / fix these?
Also I have a distorted element message that refers to an element that doesn't exist....
Accepted solutions (3)
Replies (8)
Message 2 of 9
Message 4 of 9
This doesn't really help with my distorded non-existant element. How can i identifay and repair an element that doesn't exist...
Message 5 of 9
Rafal.Gaweda
Autodesk Support
Autodesk Support
Correctly meshed model : http://we.tl/Izm5SShPQd
Check meshing options in it.
Rafal Gaweda
Message 6 of 9
Thankyou!!
Message 7 of 9
Rafacascudo
Yes it does exist.
it´s on panel number 1736 . It´s so tiny  ,it is very hard to find . But setting to display its number it becomes clearly visible with " display atributes only to selected objects".
Model has imprecisions.That´s the cause of so many mesh incoherences. Correcting these imprecisions will also make the distorted element disappear.
Rafael Medeiros
Message 8 of 9
I really don't know how to avoid these imprecisions... I model using dwgs, and always snap to end points only. I snap to a point and then snap to the same point and end up with two different locations... Is there a way of increasing the accuracy or asking the software to assume that points within a cirtain proximity are the same point.
Message 9 of 9
Hi Timo121,
You could use the detailed correction tool for this purpose (Edit>Detailed Correct). See snaphot.
