Negative value of elastic coefficient at support
Hi, please advise how do you define physically, negative value of elastic coefficient at support properties.
Pawel.Pulak
Autodesk Support
Autodesk Support
Do you mean to obtain the reaction acting in the direction of displacement?
Pawel Pulak
Technical Account Specialist
My results are correct for coefficients as per figure below. However, I am not sure how to explain it. In node of applied elastic support I have now displacements at expected values and reaction zero forces as intended. But I would like to understand math behind negative value of coefficient. Please help.
Pawel.Pulak
Autodesk Support
Autodesk Support
What do you mean by "My results are correct for coefficients as per figure below. "?
In case of negative stiffness coefficients in supports Robot assumes that they are incorrect and the analysis is performed assuming zero stiffness.
Negative stiffness is assumed by Robot as incorrect because it corresponds to unphysical behaviour where for instance downwards load causes upwards displacement.
That is why I asked in my first post whether you want to obtain such behaviour.
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
You are correct.
I thought negative value will go with direction as per tensions or compression of the spring with k stiffness.
It is wrong, then.
I will delete this thread so no one will misinterpret.
Rafacascudo
if you want your support to work in only one direction you need to set uplift direction
Rafael Medeiros
I also was curious about this.. We never had negative values on supports. unless it is run as linear equation.
