05:50 AM
I am trying to modify many bar section labels. (For example: changing all labels from HSRE to HSS in order to match the AISC Steel Manual)
I have all the desired member sizes grouped in the label manager, and am pretty sure that the label manager file is "labelmng.rtl" (path is "C:\Users\USERNAME\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis Professional 20XX\CfgUsr").
Does anyone know how I can modify these labels? Is the solution editing that file somehow? I would really prefer a solution that doesn't require going into Robot and changing every bar section label one member at a time.
Thanks!
