Workstation configuration to run a model above 200000 nodes
Message 1 of 17
Dear all,
Currently i am trying to analyze a heavy Robot model with about 200000 nodes ( It is a 70 storey building).
My laptop takes about 5 hours to run the model. Also after analyzing it is hard to rotate and filter results quickly because it is too heavy. ( Analyzed model is about 15 Gb)
I am planning to assemble a workstation to run this model quickly and filter results with following configuration
Processor     -  Intel Core i7 7700k 4.2-4.5 Ghz Quad Core (7th Generation)
RAM            -  Team elite plus 16 Gb 2400 MHz DDR4
Graphiocs    -  Palit Geforce GTX 1050 StormX 2Gb GDDR5
SSD              - Toshiba Q300 240Gb SATA 6Gbps SSD
Hard drive    - Seagate Barracuda 1 Tb 7200RPM
I would like to know whether this configuration would help me to run and analyze this model quickly and easily.
If not please give me a suitable configuration to run my model
Thank You!
Replies (16)
Message 2 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
32+ GB RAM
If you are able to reduce number of panels....
Send us model to check
Rafal Gaweda
Message 3 of 17
Thank you  Rafal.
sorry i cant send you the model at the moment.
Are you suggesting that my proposed hardware configuration will do my job with a 32 Gb RAM ?
Which hardware should i improve to make the model easy to rotate and filter after analyzing ?
Sandeepa
Message 4 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
I hope.
 Reduce number of panels in model if possible.
Rafal Gaweda
Message 5 of 17
Since it is a already modeled one by the designer the number of panels cannot be reduced.
Is there any way to send you this model to check privately. Since it is confidential.
Message 6 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
Message 7 of 17
Check private masseges
I have send you the model
Thank You!
Message 8 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
Log from calculations (Robot 2017 SP2):
I will check on 2015 SP5 later. In the meantime please install SP5 for your Robot.
08:03:06 - Structure preparation for analysis #0
08:15:12 - End of preparation for analysis #0
08:15:12 - Start of analysis #0
08:22:20 - Instability (of type 3) detected at node 30284 in direction RZ. #0
Do you want to continue?
[Press ESC to ignore all warnings] #0
08:50:14 - End of analysis #0
My laptop
(Robot uses max 6 GB RAM during calculations as far as I have seen ; so 16 can be enough depending on other opened applications)
Rafal Gaweda
Message 9 of 17
How is the ability to rotate and filter results in you machine after running the model?
Message 10 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
Check 2017 version:
http://www.autodesk.com/products/robot-structural-analysis/free-trial
then install SP2, then check your model on this version
Rafal Gaweda
Message 11 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
2015 :
09:57:53 - Structure preparation for analysis #0
10:12:51 - The element is not assigned to any story #0
10:12:51 - End of preparation for analysis #0
10:12:51 - Start of analysis #0
10:33:54 - Number of missing eigenvalues found = 1. #0
10:53:52 - End of analysis #0
More less the same time
Rafal Gaweda
Message 12 of 17
ok i will install it
But my other concern is rotating the model after analyzing. currently its very hard to rotate and select elements on my machine
Message 13 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
Rafal Gaweda
Message 14 of 17
Thank you very much !
Message 15 of 17
One other thing.. what is your Graphic Card?
Message 16 of 17
Rafal.Gaweda
Autodesk Support
Autodesk Support
NVIDIA K2100M , 2 GB RAM.
Rafal Gaweda
Message 17 of 17
Can you please show me the way to get
1) Bending moments in core wall.
2) Forces of the connection of the two towers at level 39 to 42.
3) How to perform dynamic analysis
4) I am confused with load cases generated and i want to know how to get maximum force diagrams
I have sent you the model before
Thank you!
