Wind simulation - wind velocity profile from Real Wind Tunnel
bartycorrea
bartycorrea
I'm doing a college project to compare wind pressure coefficients obtained in a real wind tunnel test and parameters obtained in CFD simulations. By now the software chosen for these simulation is RSA 2023.
The difficulty I found was to insert the wind speed profile adopted in the real test into the Robot.
After searching a bit I found this old article referenced by Autodesk https://bimandbeam.typepad.com/files/robot-structural-analysis-professional-wind-simulator-validatio...
I would like to know if anyone has clearer information on how to perform this wind profile insertion.
@Rafacascudo @StefanoPasquini6790 @okapawal @Rafal.Gaweda
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @bartycorrea
Wind profiles can be defined in CSV files. They are stored in
C:\Users\%your_login%\AppData\Roaming\Autodesk\Robot Structural Analysis Professional 2023\CfgUsr\Wind Profiles
Example of wind load profile file attached
You can open it from Wind profile tab
Krzysztof Wasik
bartycorrea
Hi @Krzysztof_Wasik
I'm having some trouble checking the wind loading generated on some of the cladding panels of my model. For example:
In some of the panels of this coverage the loads are generated normally, but in others nothing appears (even in the load table...) would you know how to help me with this problem?
In case you want to take a look at the .rtd file I can send it (it's version 2023)
