PROBLEM TO SENDING MODEL TO REVIT 2023
robsonalef12
robsonalef12
Hello Guys,
When I try send a complete model(rebars columns... )to revit 2023 only analitcs models was sent and dont show me on the options ( transfer optionally -- Rebars, columns, beamns) more. Anyone knows if in revit 2023 this option was removed ? And is possible export columns, beamsn and rebars to revit 2023 ?
EduardoMeruvia
Hi @robsonalef12 ,
As of 2023, the you can only send the analytical model to Revit and then remodel the physical model on top of it. This was done to have better control on the analytical side for Robot. I beleive maybe future version of Robot and Revit might include back the transfer of the physcical model also.
vincent_straehli
Community Visitor
Community Visitor
Hello, i am facing this problem too. Do you know if it has been solved since then?
Best Regards.
chinenyei
Observer
Observer
SEND MODEL AND RESULT FROM ROBOT TO REVIT IS GREYED OUT, WHAT COULD BE THE SOLUTION?
okapawal
@chinenyei
For direct connection, including sending results, you need to have Revit and Robot installed together on on the system.
Waldemar Okapa
Sr Product Owner
and.magro
Hello @okapawal,
What is the current state of modeling first in Robot and then exporting to Revit?
Is it already possible to send the 3D model to Revit, or is only the analytical model supported?
okapawal
Hi @and.magro
The current solution allows for sending analytical model only from Robot to Revit.
Then in Revit you can generate Physical Structural model out of Analytical one using Analytical Automation scripts included in the program...
Waldemar Okapa
Sr Product Owner
