Wind Analysis - Load Types - Full Results Access?
I am utilising the wind analysis feature in Robot. Is there a way within Robot to access the nodal values of pressure - i.e. those values that are seen in the wind simulation plot?
The load results that come out are a mix of uniform pressures and edge UDLs - but I'd like the actual pressure results that are plotted so I can do some assessment on this information separately.
Example attached - the pressure varies across the facade panels and is not constant on them - but the only values I can access are constant/uniform panel loads and edge UDLs. I'd like the actual values.
Any help much appreciated.
James
Rafal.Gaweda
Autodesk Support
Autodesk Support
Unfortunately not possible
Rafal Gaweda
