Imperfect intersection
Hello!
I have a Revit file which I exported to Robot.
I now have troubles with intersecting members not properly intersecting, i.e. I can't create a node at the point where they cross. I want the members to share a plane and transfer loads at these points. Is there an easy way to correct this?
Regars.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Edit \ Detailed Correct
Rafal Gaweda
Hello!
Thank you for a rapid reply. We had a power failure nearby so it took me a while before I could apply it. It seems to be the feature I was looking for, altough, I wasn't able to get it to work as I wanted. I'll try to look into it further tomorrow.
Thank you.
