Why is the reduced result for panels NRx value different to the reactions integral value?
HRahmanMKEP2
Message 1 of 9
HRahmanMKEP2
So I have a small building model which for information is not orthogonal to the global work-plane. When I calculate the reactions I am getting discrepancy in results between the integral reaction value and the reduced results for panels NRx value.
For one panel here is the results:
Integral reaction on this panel = 407.92 kN
Same panel the reduced results NRx = -370 kN see below:
I have also took the cut length of the panel to work out line load reaction using the NRx/cut length
and this is still different to the average reaction.
Does anyone know the explanation behind this discrepancy and does the work plane play a role in this?
Replies (8)
Message 2 of 9
Simau
Hi @HRahmanMKEP2
please zip and share your model
M. Agayr
Message 3 of 9
HRahmanMKEP2
Please see zipped attachment of the robot model without results thanks 🙂
Message 4 of 9
Simau
Hi @HRahmanMKEP2
Work-plane orientation has nothnig to do with the results. Results accurency depends on mesh size.
Some warning messages were fixed
M. Agayr
Message 5 of 9
HRahmanMKEP2
In the snapshot you have shown for both mesh sizes why is there a difference in the NRx value and the Fz I thought they were the same?
Message 6 of 9
Simau
You will never get 100% accurancy.
The smaller size the better accurancy
M. Agayr
Message 7 of 9
HRahmanMKEP2
Makes sense. What actually is the difference between Fz and NRx in this case so how is it calculating differently. Is NRx the benchmark to use for design?
Message 8 of 9
Simau
Robot uses NRx to design wallss
M. Agayr
Message 9 of 9
HRahmanMKEP2
thanks I'll close the thread 🙂
