Concrete age parameters missing from story parameter dialog box
david_hagboSEQUM
david_hagboSEQUM
I'm trying to change the life span expectancy for a concrete slab. When applying the exposure class XD3 robot demands the cover thickness to be >45mm which implies the life span expectancy to be  100 years (reading exposure class table) How do I change the life span expectancy? Searching through the internet for answers it seems I'm missing some options in story parameters dialog box. See attached images below.
any help is much appreciated. Thanks.
Simau
Hi @david_hagboSEQUM
Go to reinforcement type you affected to your slabs and change the structure calss
M. Agayr
david_hagboSEQUM
Thank you @Simau for your reply, but it doesn't seem to solve the problem. Why are the story parameters missing, and how can I activate them?
Simau
I really don't know where "story parameters" is hidden
M. Agayr
