Moving load error "Not all object form the list a exposed..."
rbaraldi
rbaraldi
I am running a moving load in my model on RSA 2025 and a error message appears "Not all objects from the list are exposed to defined planar load on contour (#10...) in load case 0.
I double check from a solved model in RSA 2024 and did not have the error, only when I use 2025.
okapawal
@rbaraldi
I RSA 2025 the load assignment has been enhanced with the detection if a contour load has been assigned to objects properly.
In case of this moving load the vehicle load definition is out of slab contour in many steps.  So this causes all warnings.
But the part of the vehicle is applied correctly to the slab.  You can check the equal load applied and sum of FZ reactions.  You can ignore the warnings in this case.
Waldemar Okapa
Sr Product Owner
rbaraldi
Waldemar,
Thanks for the replay. I am going to use this approach.
Rafael Baraldi.
