RC beam design - cannot edit support conditions (beam geometry, provided reinforcement module)
brisid.isufi
Message 1 of 1
brisid.isufi
I am designing a RC beam with the Provided Reinforcement module. In my main model, the beam is supported on a shell element, whereas in the Provided Reinforcement module it appears cantilevered. I read that this is a known issue, and the workaround is to manually edit the conditions, but the option seems to be grayed out, as shown in the figure below:
I found this link: https://forums.autodesk.com/t5/robot-structural-analysis-forum/design-of-beam-supported-by-a-panel/t... , which does not solve my issue, because
Even if I model a fictitious element (section 10x10cm) to act as a column, the program still assumes the beam is cantilevered when I update the RC element.
Replies (0)
