Why does my model return zero displacements?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Ok, so I am modeling a slab + beams and applying a distributed load on the slab.
I defined the geometry and loads.
From my verifications, everything was defined properly at first.
I did not choose anything about the meshing of the slab, I believe that caused problems.
I am able to see the load applied on the slab, and I have the supports properly defined.
The analysis keep returning an isolated node that I cannot find and my displacements return all zeros even though there are no Errors.
This should be so simple but on Robot is such a fuzz to get it done.
How do I share my file? I really need some direction because I have been googling to find out what can the problem be and I havent gotten anywhere in hours.
thanks a lot!
