Water tank with varaible walls thickness
MUHANNAD.ABU_ABDO
Message 1 of 21
MUHANNAD.ABU_ABDO
Hello to all .. i'm trying to simulate deep water tank with 27.5 m diameter & 25 m depth , but the thickness is changed every 5 meter start of 1.5 m at end to 0.3 m at top as in the pic below , i modeled the tank as solid using Revolve and i want to check if the shear stress is within allowable limits and walls thickness enough or not ! can someone help me with this issue ?
Thanks in advance
Muhannad M.Abu Abdo
Structural Design Engineer
Replies (20)
Message 2 of 21
Mohammed_Ata
I think you have 2 options:
1- Draw each 5.00m vertical strip individually, then you have a thickness per each!
2- You can use option (variable thickness along line) as shown, it presents linear variable thickness!
Message 3 of 21
MUHANNAD.ABU_ABDO
i already made the model ! i didn't mean the thickness is variable along the wall ( Linear ) i meant as in the pic below
Muhannad M.Abu Abdo
Message 4 of 21
Mohammed_Ata
I don't think so as RSA draws the area section from its geometric center!
Message 5 of 21
MUHANNAD.ABU_ABDO
Check the model file in the first post !
Muhannad M.Abu Abdo
Message 6 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Have you considered modelling the tank as a solid?
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 7 of 21
MUHANNAD.ABU_ABDO
Yes i did .. check the model in the link below ..
https://www.mediafire.com/?9alhqepy44ogh58
Thanks in advance
Muhannad M.Abu Abdo
Message 8 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
I'd say you need more elements for the precision of the solution e.g. increase number of divisions for revolving to 240 and have more elements across the wall thickness specially for the top part where you have only one row of solid  (mesh) elements. You may also consider using the axisymmetric structure model instead.
Artur Kosakowski
Message 9 of 21
MUHANNAD.ABU_ABDO
thanks for your response .. i tried to do it using axisymmetric structure ! but i failed ! due to that i used volumteric structure design .. Could you give me small video or hint how i can do it using axisymmetric ,, your help is highly appreciated
Thanks in advance
Muhannad M.Abu Abdo
Message 10 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Message 11 of 21
MUHANNAD.ABU_ABDO
Many thanks .. this is useful .. is it possible  to make  revolve for this panel ?
Muhannad M.Abu Abdo
Message 12 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
The whole point for this structure type is to work with such reduced size model as the behavior of the structure is identical at any point of the 'circle' but you can crate a panel like this and revolve it to create a solid model (in this case you should start with a solid model type).
Artur Kosakowski
Message 13 of 21
MUHANNAD.ABU_ABDO
i can't find the nature of load !
thanks for your efforts .. i appreciate that
Muhannad M.Abu Abdo
Message 14 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Could you attach your model?
Artur Kosakowski
Message 15 of 21
MUHANNAD.ABU_ABDO
Here is the model
Muhannad M.Abu Abdo
Message 16 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
I can't see any issue:
Artur Kosakowski
Message 17 of 21
MUHANNAD.ABU_ABDO
i tried to put the loads but it didn't work
Muhannad M.Abu Abdo
Message 18 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
What kinds of loads exactly?
Artur Kosakowski
Message 19 of 21
MUHANNAD.ABU_ABDO
Water pressure
Muhannad M.Abu Abdo
Message 20 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
I believe I defined linearly varying load in the video I attached to my previous answer. Do you have any issue to define such load yourself?
Artur Kosakowski
