In RC Wall module how to take openings into calculation? I'm using French Eurocode. I always got message: In calculation according to calssic method openings are not taken into account. Is this because of French code?Which codes support walls with openings?
Solved by Artur.Kosakowski. Go to Solution.
I've found this:
I need reinforcement in openings, should i use simplified method and how to do that?
Thank you!
Try to use the RC Slab Required + Provided Reinforcement modules (for a vertical panel) instead. In this approach the reinforcement is calculated based on the values of internal forces obtained in each node as well as each center of surface elements.
