walls openings reinforcement
3 REPLIES 3
547 Views, 3 Replies
In RC Wall module how to take openings into calculation? I'm using French Eurocode. I always got message: In calculation according to calssic method openings are not taken into account. Is this because of French code?Which codes support walls with openings?
3 REPLIES 3
I've found this:
http://wikihelp.autodesk.com/Robot_Structural_Analysis_Professional/enu/2014/Help/0048-User_s_G48/11...
I need reinforcement in openings, should i use simplified method and how to do that?
Thank you!
Artur.Kosakowski
Try to use the RC Slab Required + Provided Reinforcement modules (for a vertical panel) instead. In this approach the reinforcement is calculated based on the values of internal forces obtained in each node as well as each center of surface elements.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
in reply to: Artur.Kosakowski
BIG BIG thanks
