Using Scale for change it horizontal dimension through out frame, how?
I have a simple frame,  a canopy 14 ft. in width and 100 ft long.  I have my supports at 15 ft on center. I modeled the steel frame with cold formed C channels with just a few spans. However, the width of the frame changes for different sites I'm designing for.  I would like to just scale the horizontal dimension of the frame to make these changes instead of modeling every frame. I thought I could do this with Scale, any thoughts? As I have tried to do this, and really am confused by it, the members don't end up connected joint to joint as I originally modeled it. I can't scale the entire frame because I need to keep the same height. Any help appreciated. I have attached the file just in case.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Please check this video.
Rafal Gaweda
Thank you for the help and the video! It was of great help!
