concrete column base connection with CM66 code
sbvHJCLF
sbvHJCLF
Good day,
I am designin a concrete column base connection applying CM66 code, and I would like to calculate the joint with a different profile, because my column is not an IPE section, is an angular. Is it possible to change it?
On the other hand, I would like to check the comprobations that the program does in order to check what is it doing.
Is possible to see all the veryfications that are being done?
Thanks in advance!
Simau
Hi @sbvHJCLF
It's not possible, only I shape, see this post
https://forums.autodesk.com/t5/robot-structural-analysis-forum/c-shapes-bolted-connection/td-p/80025...
M. Agayr
