Update 1 for RSA 2019
Rafal.Gaweda
Autodesk Support Autodesk Support
Message 1 of 21
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi All,
I would like to inform you that Update  1 for RSA 2019 is live.
It can be downloaded and installed through Autodesk Desktop Application and Autodesk.Account.
After installation the version number will be presented as 32.0.2.
Readme document
Rafal Gaweda
Replies (20)
Message 2 of 21
Romanich
Great update!
Rafal, could you please provide more details regarding these:
Fixed over 10 issues related to Steel Design in a number of steel codes.
Fixed approx. 20 issues related to Reinforced Concrete Design in a number of RC codes.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 21
Hi.....
How can I get the update please??
Message 5 of 21
mustafahesenow
Hi @Rafal.Gaweda
Thanks for this update which to see much more in the coming version.
I would like here to ask that this update to be applied not only in 2019 Version it should be applied on versions 2015 2016 2017 & 2018 as well if that possible.
Many thanks.
Mustafa Hesenow
Senior Structural Design Engineer/MZP
LinkedIn
Message 6 of 21
Awesome! I'll try it out and see if it fixed some issue that I'm facing right now!
Message 7 of 21
Hey!
Just go to your Account and then to Manage Products & Downloads. Once in the list of available programs for you, go to Robot Structural Analysis Professional. Go to Download and from there look for Updates & Add-ons
Hope this helps!
Message 8 of 21
Mohammed_Ata
It is great update but, i can't get the link to download. Please can you attach a direct link !
Message 9 of 21
Simau
Hi @Mohammed_Ata
I agree, the search for updates is very complicated on the ADSK site, so here is a direct link
https://wetransfer.com/downloads/0c0556676f679cadab4b5c5fdcf0600020180913145522/5f52ec89c914ebaa03e3...
M. Agayr
Message 10 of 21
Hello
Just go to your account, or basically the same place from which you downloaded RSA the first time. After clicking on Download just go to the third tab on the right and you will see the available updates.
I don't think is that difficult and personally I'd stick to the official website.
Message 11 of 21
Mohammed_Ata
I faced an error installing, please give me a solution for this !
[video]
Message 12 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Mohammed_Ata
Try to uninstall Robot 2019 and then install it again (do not remove msi file this time). Then install the Update 1.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 13 of 21
Hello.
The error your are getting isn't related to RSA, but to your Windows' Configuration. Try this fix and see if it works for you!
https://www.youtube.com/watch?v=RPQcRNljkXk
In any case focus on solving this error:
"The feature you are trying to use is on a network resource that is unavailable"
And which is Windows related.
Message 14 of 21
@Romanich wrote:
Great update!
Yes, I would like to know if one of the issues i pointed out are already fixed. Like the SLS design check member parameters not same as ULS design check
Message 15 of 21
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I have already updated all the posts on the forum that were relevant to the improvements provided within the Update 1. The situation you described wasn't the part of the Update 1 😞
Artur Kosakowski
Message 16 of 21
wassim_said_said
Dear Artur,
Thank you for the 2019 update 1  clarifications . it was great as usual from your part.
But in the other language forums there was a lake of informations concerning the update 1 of RSA as shown in this blog in the French Forum:
https://forums.autodesk.com/t5/robot-structural-analysis/nouveautes-rsa-2019/td-p/8249608
Can you deploy the updates links to the other forums as all users of RSA may benefit from these updates.
Thank you in advance.
Wassim
Message 17 of 21
@Artur.Kosakowski wrote:
Hi @Anonymous
Yeap, I checked it again and it is still there, I hope you guys can give us a Halloween treat/Christmas present with fixing this issue.
Message 18 of 21
Could anyone send me direct link please ?
Message 19 of 21
edu.poletto
Awaiting for ABNT NBR implementation in Robot.
Cya.
Message 20 of 21
MaciejWiśniewski8143
Can you publish the update again Sir?
BRG MW
