highlight only particular elements (which haven't passed the mesh quality test)
I wrote this line in my C# project:
wall1.Mesh.GetQuality(out double _out_q1, out double _out_q2, out string _out_fes, 0.01, "All");
_out_fes thus contains a list of all elements which have failed the mesh quality test. I now want to highlight only these failed elements in my ROBOT drawing. How can I achieve this through the API?
Looking forward to your guidance.
Rafal.Gaweda
Autodesk Support
Autodesk Support
Hi @Anonymous
Highlighted objects in Robot are selected objects.
First you need to Get such selection with API (it can be empty). Then fill it with your list = string
Example:
    Dim RSelection As RobotSelection
    Set RSelection = RobApp.Project.Structure.Selections.Get(I_OT_FINITE_ELEMENT)
    RSelection.FromText ""
    RSelection.FromText YOUR_STRING
Rafal Gaweda
Hi @Rafal.Gaweda,
Thank you so much for the guidance. It works like a charm
