Dear all,
I am currently working on the optimisation of a structure used in thermal treatment lines.
The structure is composed of both panels and bars.
Recently, I tried changing the thickness of my panels (from 5mm to 4mm). However after the calculation, my results were completely wrong (see below picture)
I thought that you guys might have a solution about this, because it is impossible to find one on the internet.
Thank you for all your future answers !
Solved by Rafacascudo. Go to Solution.
can you zip and attach the model?
Rafael Medeiros
Unfortunately, as it is a strictly confidential project, I am not allowed to upload it...
by the picture you sent , the mesh seems to be very bad. Hard to tell what is wrong , without the model.
Try Artur´s sugestion on this thread here
Rafael Medeiros
Check material properties and thickness if mistakenly they not too high.
Does the wrong results display on a single load case or all cases? If this is a problem with a specific load case try to remove and redefine the load case.
It worked ! Opening the model in repair mode solved the problem. Thanks a lot for your help.
