SOLID (VOLUMETRIC) OBJECT CREATION
Good morning Support,
I am trying to create a foundation that is combined from two objects of different depth.
I was using the 'face' object to create the faces and to change it to solid, but when I am opening the solid dilog box and try to do the operation it don't work.
Would you be able to explain how to create this type of structure or guide to a place that does that.
Is there any more advanced guide on using solid structures?
Also could you please explain how I should properly aply rigid links to the solid objects. I would like to use them on my supports and probably some of the columns to run away from applying surface loads from bending moments.
Looking forward to hear from you.
Kind Regards
Jan
Artur.Kosakowski
Autodesk Support
Autodesk Support
Artur Kosakowski
Thank you Artur.
Really good tutorial.
I believe it would be worth pin it somewhere at the top of the forum or do a IQ session about solid modeling.
Jan
Artur, i can´t find the way to create a volumetric solid in RS 2019. In fact, i can´t find the commands shown in the tutorial video. The program documentation is not helping me. Any help please?.
Romanich
Hi @Anonymous ,
Please make sure that you change the structure type.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Romanich, of course that was my mistake. Thank you.
