Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Unexpectedly high soil bearing capacity from Analytical stress method (EC 7)
2 REPLIES 2
umut.akparlar
137 Views, 2 Replies
I wanted to design a pad foundation on a clay ground, and it has approximately 150 kPa bearing capacity. I can use semi empirical stress method and enter the bearing capacity manually. When I wanted to use the analytical model, I will have a much bigger bearing capacity with selecting similar soil specs from soil database.
Semi empirical
Analytical:
qlim is nearly 2.2mPa which is not expected for a clay ground.
Kindly provide input on this.
2 REPLIES 2
Simau
in reply to: umut.akparlar
Hi @umut.akparlar
How do you get qu = 0.15 MPa with semi empirical method and why do you choose ground clay in the analytical method.
Are these values from a geotechnical report?
M. Agayr
umut.akparlar
in reply to: Simau
Hi @Simau
We have approximate bearing capacity value from a similar site but I don't have a detailed geotechnical report.
I selected clay because there are other buildings at that site with clay soil and I assume clay for preliminary design purposes.
Assumed clay bearing capacity values are much lower than analytical method:
