Hello ;
I'm designing a RC building . I've applied thermal load on the slab. I'ts a uniform thermal load dT1 = +10 .
The problem is the membrane force that result from this termal is not uniform and have weird distribution.
See the picture .
Hello ;
See the picture .
Solved by Simau. Go to Solution.
Maybe the panel local axis are not pointing at the same direction.
Select "According to X axis" instead of "Automatic direction"
M. Agayr
M. Agayr
Hello !
Thanks for responding.
The local axis are not pointing at the same direction for all slabs , but the problem still persit .
See the attached model .
Hello !
Your structure is not "uniform"
Rigidity is different in X and Y direction.
Shear walls will bloc the expansion more than RC portals frame.
So don't expect a uniform distribution as in the example below.
M. Agayr
M. Agayr
Thanks you very much !
I understand now why the membrane force is not uniform .
