Hello everyone, Is there a way to design the web elements of a Truss (diagonals, and vertical elements) individualy? I mean Select the correct section without using the group member design tab, similar to the SELECT command in staad pro.
Solved by Artur.Kosakowski. Go to Solution.
You need to create groups but you can do this automatically in this way:
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
