Truss web elements design
danielrmc1726
danielrmc1726
Hello everyone, Is there a way to design the web elements of a Truss (diagonals, and vertical elements) individualy? I mean Select the correct section without using the group member design tab, similar to the SELECT command in staad pro.
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @danielrmc1726
You need to create groups but you can do this automatically in this way:
automatic design groups.JPGIf I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
danielrmc1726
Thanks artur!
Grettings from México!
