Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Truss support analysis
4 REPLIES 4
445 Views, 4 Replies
I'm currently analyzing a truss but I'm just wondering if it is possible to do a plate connection in the support for example a pinned support like the imaged below. If possible can you guide me how to do the support analysis.
Thanks in advance.
4 REPLIES 4
Rafacascudo
You can try modelling the plates as FE elements panels and conecting them to the bars using rigid links
Rafael Medeiros
in reply to: Rafacascudo
Thanks for the quick reply
Any link or tuitorial for this sir?
Rafacascudo
Something like this.
On a simple model the hole edge connected with rigid links all around (you can link all edge nodes .I linked only the polygon nodes for this example)
On a more sophisticated model you can link e hole edge with compression only bars to simulate the real contact with the support plate
Then , the results
1- vertical force on the plate for model with rigid links to the hole edge
2- vertical force on the plate for model with "compression bars only" to the hole edge
you can see that compression in the plate on the region below the hole is much larger for the  model with "compression only bars " instead of rigid links to transmit the force to the plate.
I needed to add some extra supports to avoid some instabilities
models attached
Rafael Medeiros
Wow thank you Rafa for the tuitorial.
I'll try to practice this and then I will give you a feedback.
Much appreciated for the time.
