I'm currently analyzing a truss but I'm just wondering if it is possible to do a plate connection in the support for example a pinned support like the imaged below. If possible can you guide me how to do the support analysis.
Thanks in advance.
Solved by Rafacascudo. Go to Solution.
Rafael Medeiros
Something like this.
On a simple model the hole edge connected with rigid links all around (you can link all edge nodes .I linked only the polygon nodes for this example)
On a more sophisticated model you can link e hole edge with compression only bars to simulate the real contact with the support plate
Then , the results
1- vertical force on the plate for model with rigid links to the hole edge
2- vertical force on the plate for model with "compression bars only" to the hole edge
you can see that compression in the plate on the region below the hole is much larger for the model with "compression only bars " instead of rigid links to transmit the force to the plate.
I needed to add some extra supports to avoid some instabilities
models attached
Rafael Medeiros
Wow thank you Rafa for the tuitorial.
I'll try to practice this and then I will give you a feedback.
Much appreciated for the time.
