Truss Frame Structure
Message 1 of 20
Hi, I'm designing a truss frame structure with roof and wall bracing, however, I'm getting a stability error 2 when I change my supports to pinned and not sure why. I have made all truss and bracing members compression/tension elements with N/A supports. Does anyone have a solution for this?
I have attached the model.
Replies (19)
Message 2 of 20
saclovitzky
I do not have any problems running it.
Message 3 of 20
Hi, running it is not a problem. I want to change the supports to pin
ended, however, it gives me stability errors when I do that.
Message 4 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Set the posts and diagonals as truss bars (no bending) but keep the chords continuous.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 5 of 20
Thanks for the reply Artur,
I tried changing them to truss bars, however, it automatically ticks tension/compression box. I'm also not getting any tension in my bottom chord when I apply an area load, it shows everything acting in compression. I have uploaded the updated model with area load.
Thanks for you help, really appreciate it.
Message 6 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I unmarked tension/compression box leaving only truss marked on my picture :-).
Artur Kosakowski
Message 7 of 20
Hi Artur, sorry I was highlighting them all and then opening the dialogue box expecting them to be on just truss, bit it's a command. However, i'm still getting a instability type 2 when i convert all the base connections to pinned as shown below. There is something which is also affecting my axial force, the bottom chord is showing that it is in compression as well as the top chord which cannot be correct. I can't seem to find what the problem is with this one.
Message 8 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Why RZ at the reactions shouldn't be blocked? Do you allow the columns to rotate about their own axes?
Artur Kosakowski
Message 9 of 20
Hi artur, thanks for the reply. I thought by having beams at the other end, this takes care of rotation of columns, I've seen other models with pinned bases and no stability error. Do you know why I'm getting compression in the bottom chord?
Message 10 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try to block RZ at supports (otherwise you'd need to carefully explore the releases and truss bar arrangement) so that there is no instability. Calculate the model - hopefully tere should be no compression there. If there is and check the deformation shape which should give you the answer for your question.
Artur Kosakowski
Message 11 of 20
Hi Artur, I understand the releases, however, the deformation shape shows the correct outcome.  I really don't know what's causes compression in the bottom.
Message 12 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Could you attach the latest version of the model?
Try to display diagrams in this way:
Artur Kosakowski
Message 13 of 20
Hi Artur, i've uploaded it. The numbers also show that the bars are in compression. I've double checked everything. If you could have a quick look over it, it will be much appreciated. I currently don't have anyone in office to look over it.
Message 14 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
You either need to allow the bottom chord to move horizontally (so that it is not restrain by columns) or change its shape:
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 15 of 20
Hi Artur, the bottom chord should go into tension no matter what due to the
truss load.
Message 16 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
I disagree. IMHO this depends on the column deformation.
Artur Kosakowski
Message 17 of 20
Thanks for the reply and sorry for all the questions. I created a separate
model and it shows the results differently. I have attached it.
Message 18 of 20
Hi Artur, I agree with what you said and I've checked it. I'm not sure why, but i'm getting stability errors after changing the bases to fix in rotation about it's own axis. I have attached the model if you have time to have a quick look.
Message 19 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
What about the top roof purlins?
Artur Kosakowski
Message 20 of 20
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Can we consider this topic as solved?
Artur Kosakowski
