TRIANGULAR ( PRESSURE ) LOAD DISTRIBUTION AT A SPECIFIC DISTANCE
Eng.LuayTareq
Message 1 of 9
Eng.LuayTareq
HI EVERY BODY ,
I WOULD LIKE TO KNOW HOW CAN I DISTRIBUTE THE PRESSURE LOADING A SPECIFIC DISTANCE ON A PANEL USING COORDINATE PARAMETERS GIVEN IN PANE SURFACE LOAD
WITH MY GREAT THX TO YOU ALL
Replies (8)
Message 2 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Eng.LuayTareq
I'm not sure if I understand what you need exactly. Could you attach some sketch illustrating your question please?
Artur Kosakowski
Message 3 of 9
Eng.LuayTareq
I  want to design a rectangular tank of 4m*5m with a height of 4m from calculation the load on each panel of the tank will be P=44.07 KPa at the bottom of the tank and decreasing uniformly to zero at 3m high , so my question how can I enter this pressure using Load Definition ?
with all my best
Message 4 of 9
Rafacascudo
3p load or hydrostatic types
Rafael Medeiros
Message 5 of 9
Eng.LuayTareq
yeah the 3p but I don't understand how to enter the exact coordination parameter given in it so that the load decrease to zero at 3m hight not the whole height of the wall =4m .
Can I get an explanation to help me how to get a solution for that ..
Best,,
Message 6 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Eng.LuayTareq
Please check post 2 from https://forums.autodesk.com/t5/robot-structural-analysis-forum/applying-hydrostatic-pressure-to-only...
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 7 of 9
Eng.LuayTareq
@Artur.Kosakowski ,, yes Mr. Artur I have the same problem but the solution given in this forum did not open requiring me to refresh the page , is there another forum solving the same problem
Great thx to you
Message 8 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Eng.LuayTareq
post number 2 Smiley Wink
Artur Kosakowski
Message 9 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
For the geometrical limits:
Artur Kosakowski
