- Mute
- Permalink
- Report
I am designing a waterretainng tank which has two compartments. In design I need to consider the load effects when both sides are loaded and also when one side is loaded only.
When I apply hydrostatic loads I seem to be only able to specify the pressure details then apply to the full panel which works ok for the "both sides loaded scenario" but not the case where only 1 side is loaded. The outer wall of the model, which was defined in revit, spans the full wall length. I know that the panel could be shortened to stop at the internal wall then create another panel for the other side but this seems counter intuitive.
Is there a way when applying to hydrostatic pressure to a wall that you can specify a contour to which the load applies? I can see geometcial limits option in the load definition box but really struggle to understand what it is saying, maybe it is the solution though?
Thanks for your help guys.
JTL
