Totally different of wind simulation
Dear All
When i'm simulating of wind load. have been 2 method at bellow:
1. the first, simulation wind load, and then calculating the model
2. I was simulated wind load when the model has been calculated (none wind load). And then calculating again.
I has been see the momen of 2 method is totally different.
Some one can check my model, and answer me
Rafal.Gaweda
Autodesk Support
Autodesk Support
Thanks for reporting.
It must be checked by developers
Rafal Gaweda
And, i have another question
 With the determine wind load by method wind simulation on RSA, this issue was included Static Wind load and Dynamic wind action or not ????
I thing it only has Static wind load, Because The dynamic wind action calculated by parameters : the frequency, load to mass and displacement...
You know, the dynamic wind action is very important with building tower.
Can you help me....
Rafal.Gaweda
Autodesk Support
Autodesk Support
Static Wind load
See also:
http://forums.autodesk.com/t5/robot-structural-analysis/wind-dynamic-fluctuating-ripple-component/m-...
TRy your model this way:
Rafal Gaweda
thanks you so much...
it mean device the cladding by stories is needed
thanks again...
Thanks you somuch...
thanks for take care to my model and traning to me
