Torsion steel beam
Torsion steel beam
Michele100100
Message 1 of 14
Torsion steel beam
Michele100100
I'm designing a steel  structure and I have a problem in torsion with all the C-section beams on the border :
I have loaded structure with loads on cladding, but in the reality I have a metal deck.
Unfortunately I have this verification:
Tau,ty,Ed/(fy/(sqrt(3)*gM0)) > 1
How can I solve? I'm pretty sure that those beams on the border are not going in torsion because of the welded steel deck on top; there is a way to eliminate this verification or block beams to go in torsion with some releases?
Those beam are already full fixed between them.
Thanks.
Replies (13)
Message 2 of 14
Simau
@Michele100100
Try this:
Split bars on borders and add a support at these created nodes
M. Agayr
Message 3 of 14
Michele100100
Thanks for the advise, but I tried and still have bar in torsion.
attached the model if you can have a look, bar/beam example is n.181.
Message 4 of 14
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Michele100100
In case 3 you have defined torsional moments on side beams.
Krzysztof Wasik
Message 5 of 14
Simau
@Michele100100
I divided all UPN 100 in individual members
I set them as CL type
All ratios are < 1
Model attached
M. Agayr
Message 6 of 14
Simau
I forgot to say that i set  the claddings as one way Y
M. Agayr
Message 7 of 14
Michele100100
it was because in that location I have handrails calculated by hands.
Message 8 of 14
Michele100100
hello,
I can't see your model because I have 2020 RSA Version.
Could you save in 2020? thanks
Message 9 of 14
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Michele100100
If you are applying torsion moment directly to edge beams you cannot expect zero torsion in those members.
If you assume that that torsion will be transferred by plate welded to beams (and plate is not simulated as structural element in the model) remove torsion loads.
Krzysztof Wasik
Message 10 of 14
Michele100100
ok,
This is the detail:
In my idea UPN100 can't be in torsion because of the deck. Taking off the torsional load it is correct even for this case? Thanks
Message 11 of 14
Krzysztof_Wasik
Autodesk Support
Autodesk Support
Hi @Michele100100
If UPN100 cant't be in torsion (according to your simulation idea) do not apply torsion to them.
Krzysztof Wasik
Message 12 of 14
Michele100100
Message 13 of 14
Simau
@Michele100100
Sorry, Robot 2020 is no longer installed here.
Just follow the steps discribed in messages 5 and 6 and you'll get the model as i modifieded it.
No problems even if torsion is added at UPN 100.
M. Agayr
Message 14 of 14
Michele100100
OK, thanks,
I will try how you advise.!
