Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Timber Member Design Check
35 REPLIES 35
Message 1 of 36
simjack
2051 Views, 35 Replies
I am carrying an assessment of a timber truss.
I assigned each member a "Member type". For example, member 8 is a "top Chord" member type. The effective length for buckling above major axis has been defined to coincide with points where the member meets adjoining elements and for buckling along minor axis every 400mm. I tried to define bracing for "lateral buckling" at every 400mm as well, however, when I run the analysis the effective length comes as 7.09m Do you know why is that?
Also I was wondering, does the software automatically set up the material parameters for an appropriate load duration? And the deflection values, are those final deflection values including creep?
I have attached the model and was wondering whether you could have a look and advise on the issue or point out any other issues connected to the model.
Thank you
35 REPLIES 35
Message 2 of 36
Artur.Kosakowski
in reply to: simjack
Hi @simjack
You missed the model.
Artur Kosakowski
Message 3 of 36
simjack
in reply to: Artur.Kosakowski
Sorry, I try again.
Message 4 of 36
simjack
Any ideas anyone?
Message 5 of 36
Simau
Hi @simjack
You haven't created a "top chord" type of element, but only a name "top chord".
You need to create a new type of bar as shown in the screenshot below
M. Agayr
Message 6 of 36
simjack
in reply to: Simau
Hi Simau,
I think that is what I have done.
If you have a look you highlighted "Elelement de construction" in properties box but "type de barre" in a pop out window?
Message 7 of 36
Simau
@simjack
Sorry, my Robot is now busy with a hugType de barre2.jpge lodel, so i can't make a new screenshot.
You have to create a new type.
LMK if this modified screnn is understandable, if not i'll make a new one asap.
M. Agayr
Message 8 of 36
Artur.Kosakowski
Hi @simjack
You may find the recording of the 3rd Robot webinar helpful as the principles of the timber design in Robot are exactly the same as the ones for steel design.
See: https://forums.autodesk.com/t5/robot-structural-analysis-forum/robot-structural-analysis-webinars/td...
@Simau Thank you for your help.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Artur Kosakowski
Message 9 of 36
simjack
in reply to: Simau
Thank you for your quick reply. I am going to do what you said, create a new type. I dont understand however how is it different to what I have there now?
Message 10 of 36
simjack
I feel like i've done what the video says. I've defined the internal bracing for lateral buckling at every 400mm but yet I am still finding the effective length to be 7.33m (screenshot2) I cant figure out why?
Message 11 of 36
Simau
Hi
Your model and results are corrects
M. Agayr
Message 12 of 36
simjack
in reply to: Simau
however, why is the lateral buckling length being 7.39m I tried to define it as 400mm?
Message 13 of 36
Simau
@simjack
You must check this option:
See attached picture
M. Agayr
Message 14 of 36
simjack
in reply to: Simau
that one is for buckling, not LTB and this one seems to work?
Message 15 of 36
Simau
@simjack
it seems to me that you are not convinced.
what do you mean by LTB
There are 2 possibilities of buckling, one in Y direction, that is to say in the plane of the truss, and one in Z direction, that is to say out of the plane of the truss.
In the out-of-plane direction L and Lf = 40cm
In the plane of the truss L  (bar 8) = 7.94 and Lf = 2.33m
See  attached Pics
M. Agayr
Message 16 of 36
simjack
in reply to: Simau
Im not convinced at all. LTB = lateral torsional buckling for members imposed to flexure
Message 17 of 36
Simau
@simjack
Sorry, my mistake du to a mismatch between french and english.
Yes you are rigth.
By defining Top chord type, use relative length option ( 0.4/7.95 = 0.05)
See pics
M. Agayr
Message 18 of 36
simjack
Hi Arthur,
Could you please have another look at the model and comment on your thoughts? I seem to be going in circles here. I defined the lateral restraints for all buckling in Y and Z axis, for LTB (for the top flange only as I dont think there's a requirement to apply any to the bottom flange since it should be in compression?) and yet getting strange effective lengths for lateral buckling. Could you please comment as at the moment I have no confidence in my model and results I am getting.
Also is the deflection taking creep into account?
Thank you
Message 19 of 36
Simau
@simjack
Yes you need also to defined lateral restraints for bottom flanges, as they may be in compression.
M. Agayr
Message 20 of 36
simjack
in reply to: Simau
You're right. However, I did apply it in my latest version (r2) and it still didnt make any difference.
